Home > Technical (L322) > Airbag light
Crispian22
Airbag light
Got a airbag light come up on my dash today.
Using a icarsoft diagnostic tool,It's bringing up a fault code of B1192 indicating Battery disconnect deployment control.
Whatever that is.
Anyhow,tried to clear it but it just comes back after a short while.
Any pointers folks?
TIA.
Post #442562 24th Jun 2017 1:28pm
Crispian22
Post #442563 24th Jun 2017 1:29pm
holidaychicken
If it's the same as my 04 it is the battery disconnect unit on the battery, it basically fires off a plunger and disconnects the main battery cable in the event of the air bags deploying but leaving the internal electrics functioning.
It could be faulty as there are two tiny wires connecting to the yellow connector on the battery if it's the same as mine.
My Allcomms clears mine after about 30 seconds. You could check the connector but make sure the electrics are off and ideally disconnect the battery first.
Post #442601 24th Jun 2017 8:49pm
Crispian22
All sorted with a good charge of the battery.
Guess voltage was a bit on the low side.
Post #442659 25th Jun 2017 1:39pm
holidaychicken
Mine would come on generally after a flat battery or a disconnect, temperamental but of kit ( the fatty that is )
Post #442690 25th Jun 2017 9:19pm
