Home > Off Topic - Other Cars > 3.9 RRclassic fuel pump primes but then does not deliver
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
SORTED NOW! Thanks for looking thou.
Hi
Relative new boy to this forum but am very impressed with the info here. I have been having trouble getting a 14CUX hotwire started and after replacing most of the the ignition system inc coil, dizzy cap, amplifier, r.arm, leads plugs, temp sender, new fuel etc I have just discovered that the fuel pump primes well but then does not deliver upon cranking.
Why would this be?
Every time I took the plugs out I could smell fuel so was mislead into thinking that side of the problem was ok. In desperation I have just disconnected the fuel supply line at the rail and put it into an empty milk bottle. It primes and fills about 3/4 of an inch of fuel in the bottle and stops. Great, so it primes ok, fuel filter must be letting fuel through, relay and pump work. But when you then crank there is zero fuel coming throu!!!
Any suggestions would be very welcome. Thumbs Up
Thank you 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #442565 24th Jun 2017 2:16pm
