Home > Technical (L322) > CCf file roll back? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Gents can you roll back the CCF file? I have an HDC fault as well as airbag fault showing replaced battery just in case but it is not connecting to the rear diff or the transfer box thinking maybe a something software any ideas accepted oh and have the mandatory matches and firelighter |
23rd Jun 2017 4:24pm |
Meant to say will be using the 11D tool |
23rd Jun 2017 4:52pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
the iidtool backs everything up on activation so when you mess up you can revert back to the original settings.. ... - .- -.
23rd Jun 2017 5:57pm |
Ah thanks chaps a bit of searching and I found how to do it all back to nearly normal just the airbag light left on which I think is faulty airbag as tested all the way through.
23rd Jun 2017 6:54pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
Airbags are replaceable, and if you feel you don't need the particular airbag buy need and mot there is a way around it |
23rd Jun 2017 8:39pm |
Thanks Lukie but it is the main passenger one so I will just replace it Mot was done 2 weeks ago before fault showed |
23rd Jun 2017 8:49pm |
