Home > Off Topic > Karchar Pressure washers |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
Low water pressure? |
29th May 2017 4:54pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7948 |
Mine sometimes does that when I first start - and I put it down to low pressure until it's built up a flow |
29th May 2017 5:30pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
The last one I had did that all the time. It still worked ok but I think there was a problem with the pump. It could be low wster pressure, as said, but if you rule that out I would be inclined to pursue the warranty. John
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
This used to happen on my old one. My hozelock end on my hose had a valve in it to stop water coming out, except when you had an attachment on or it was plugged it to the jet wash.Called a Hozelock WaterStop. Very handy except the valve inside pushed slightly on the inlet for the jet washer so didn't get 100% flow of water. Replaced with a straight through hose end and worked fine after that. Jordan
29th May 2017 8:38pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
I'm on my third Karcher. There will not be a 4th. They are pants!.
30th May 2017 12:42pm |
30th May 2017 12:43pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
I'm on my first Karcher which I bought 23 years ago. Never been the slightest problem. |
30th May 2017 2:18pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
I never thought of that and yes, I do have one of those type of ends on the hose !! Will report back whenI have tried a different end. |
30th May 2017 4:53pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
I have been using this once you have used a petrol one you wont go back.. power is so much better..
30th May 2017 7:25pm |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
Forget Kärcher and go for Kränzle. Hot water, foam spray, high/low pressure everything you want and they last for (almost) for ever. 2017 Range Rover Vogue TDV8 silicon silver
31st May 2017 6:12pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I have a nilfisk, which is ok, but yearn for a kränzle.
31st May 2017 8:29pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
Gerni used to be the go to brand. In fact, we use "Gerni" to denote pressure washers much like the British use "hoover"
Does that mean good or bad? In Oz, "the ant's pants" means very good - much like this Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
31st May 2017 11:09pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
1st Jun 2017 4:48am |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
things just aren't built like they used to be, the world is now disposable, after a few years it's well out of date and probably knackered |
22nd Jun 2017 8:26pm |
