Home > Technical (L322) > Key won't turn in ignition fix 2002-2005 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8338 |
I don't think there is enough room... much easier to take the column out... Pete
21st Jun 2017 7:08pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Ok noted.Many thanks for your kind replies |
22nd Jun 2017 9:30am |
Good day to all
9th Aug 2017 10:15am |
To change the magnet is a two minute job, remove the circlip, (red arrow) use tweezers and pull off all the bit's of the old magnet (yellow arrow, this one is not broken, yours will be broken if it needs changing) then put the new magnet in and replace the circlip.....
9th Aug 2017 4:27pm |
Haylands many many thanks for your assistance
10th Aug 2017 2:27pm |
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 307 |
Not sure if mine has this issue now too. Fecking car loves finding stuff to get replaced weekly.
10th Aug 2017 3:17pm |
tomo_ Member Since: 24 Jul 2015 Location: PL Posts: 9 |
just for everyone awareness: whenever I leave the car for couple of days (so to say week) and battery gets little weak I got intermittent problems with steering lock.
27th Sep 2017 7:29am |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Well yesterday I suffered the solenoid failure, the fuse 18 pull/replace worked a few times then stopped working so I followed the info in this: http://l322rangerover.blogspot.co.uk/2017/...eaded.html and hey presto I'm mobile again, albeit with a couple of sewing pins floating around.
7th Dec 2017 3:33pm |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 |
In the end to solve my steering column lock problem, I removed the steering column and sent it away to Turner Diagnostics, apparently the only people in the world that can fix this problem. They fixed it and it's been perfect ever since. Cost me around 700 quid though, more than it should have because a land rover specialist drilled a hole in the column to squirt wd40 in, according to Turner Diagnostics that is a big no no. |
7th Dec 2017 4:48pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 318 |
"only people in the world that can fix this problem" ..... perhaps in GB, but in rest of the world they send it to Düsseldorf in Germany, official can repair, 700 GBP is correct Price. We drive to the clients in radius of 200km, repair, all.incl. 900 Euro. We repair from 2002 to 2009, four hours working.
7th Dec 2017 5:18pm |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
Well there are two local garages here in Dubai that have figured out a workaround on this problem without replacing the steering column. I know two people who have had their 2003s fixed there. I had the chance to interrogate one of the vehicles with a iCarsft 930 scanner.
31st Dec 2017 9:33am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
31st Dec 2017 11:00am |
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 |
I did get the emulator to work but had to bridge pins 3 and 5 in order to pass through the park/neutral signal. |
26th Dec 2018 8:13pm |
BigJon Member Since: 05 Apr 2013 Location: Adelaide - Lower Mitcham Posts: 14 |
I just fixed a 2008 by a simple wire bridge.
26th Sep 2022 8:42am |
