Home > Site News & Feedback > Link to Google Drive Images ?
On a "normal" web page I can display a public file from my Google Drive using this code:
<img src ="https://drive.google.com/uc?export=download&id=0B5al230KXbSyUVlUdnprbW5lbG8">
Have tried a few alternatives but either get the link, blank or "<img>"
Is there an equivalent syntax for the forum ?
(note: had to disable html to get the above link to show Wink ) .
Post #431202 14th Mar 2017 6:26pm
Martin
Site Admin
You need to find the Google Drive URL for the image which ends in its extension, like .jpg, .png, .gif etc
The link you've provided is the "force download" link which won't ever embed correctly as an image anyway.
Post #431208 14th Mar 2017 7:12pm
p38arover
Australia
I've given up trying to post photos anywhere from Google Photos. I used to use Picasa for photo hosting but since Google dropped it, I haven't worked out a satisfactory way to post. The image links no longer end in .jpg
I'm moving all my photos to Flickr but I'm concerned that all my older posts in various fora might end up with broken links so I can't delete my Picasa albums yet. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #431211 14th Mar 2017 7:54pm
@ Martin
I know where you are coming from but beg to differ:
http://tsah.co.uk/tsah/gditest.html
Screenshot of page:
html: gditest.html
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8" />
<title>Google Drive Image Embed Test</title>
<meta name="generator" content="Geany 1.27" />
</head>
<body>
<h1>Google Drive Image Embeddded!</h1>
<img src="https://drive.google.com/uc?export=download&id=0B5al230KXbSyUVlUdnprbW5lbG8">
</body>
</html>
Is it just the way the forum handles this type of link ? .
Post #431228 14th Mar 2017 10:02pm
mzplcg
Not sure if it's just this forum, Google photos is a PITA will all the forums I frequent.
Dropbox is (was) better until they did away with the PUBLIC folder.
Photobucket works well with forums but the entire site is made up of adverts and trackers. Fine if you can live with that but I can't.
The best one at the moment is Onedrive although I had to set the images folder to be un-encrypted so the forum can actually see the file. If you're an Office 365 subscriber you also get 1TB of free storage which is a bonus.
Something else you might want to consider is how Google use your data. I used GD for a while until I started getting strange adverts and marketing emails which could only have been based on the GD content. They are clearly data mining on it so encryption is essential IMO.
Post #431247 15th Mar 2017 7:48am
surely the easiest solution would be to upload a pic from your hard drive to the forum server ...that way it will always be visible here despite whatever happens to flickr or any other off site storage... ... - .- -.
Post #431251 15th Mar 2017 8:05am
Martin
Site Admin
If you can't get a .jpg .png etc link out of Google Drive then the forum won't embed it. There is no reason for Google to have done it like that, except to be awkward and throw their weight around.
As Stan says the forum gallery space is there to use, it's free and fully integrated into the forum.
Post #431257 15th Mar 2017 9:11am
p38arover
Australia
At the moment Photobucket doesn't use HTTPS so it will start getting flagged as an unsafe site by Google. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #431362 15th Mar 2017 9:34pm
p38arover
Australia
You might try this: https://www.labnol.org/internet/embed-goog...ite/29194/
I can't get it to work just yet. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #441833 17th Jun 2017 11:22pm
@ p38arover
Best one can get from that approach for the forum is a direct clickable link to the image:
https://lh3.googleusercontent.com/5mD1rS33...0uVi3FUqTA
As Martin says, this forum needs an image extension in order for it to work.
I have noticed that Google Groups generates images with an extension if you post or link images there, but it is a bit long winded to do the upload there then link back to here! It is probably also possible to do this through Google Sites, but with the same caveat.
Good find though, labnol has some good stuff for google coding Smile .
Post #441834 17th Jun 2017 11:54pm
