Home > Technical (L322) > How to switch off the "Adaptive" part of Cruise
GraemeS
The radar fuse can be removed at any time but a restart is required before standard CC will work.
Yes, select the non-ACC option on those parameters, such as 'standard speed control' or simply 'speed control'. 1 or more parameters have multiple ACC options so best to note them before changing in case you want to re-activate ACC. Other CCF parameters exist that are only used if ACC is fitted/enabled so those should be left untouched.
Post #441468 14th Jun 2017 12:25am
Well a 400 mile round trip today gave me plenty of time to try all combinations of CC switches. Nothing I did turned the dreaded "adaptive" off. Double clicking the set switch just increases the speed by an MPH or two. Multiple clicking increases the effect. Holding no different. Minus does the opposite as you'd expect. Holding the distance buttons full in, full out or both together doesn't do it. I'm guessing that if there is a method it will be one of those weird ones (like the old phone paring methodology) which has to be described in a 17 point tech bulletin as its so counter intuitive.
I'll fire up the IID tool next week and see if I can beat the system that way.... Mike - MPx
Post #441732 16th Jun 2017 10:08pm
i finally found where i had read the info in my previous post,
it seems to work for him..... ... - .- -.
Post #441757 17th Jun 2017 8:36am
GraemeS
His signature line has '17 Range Rover V8 Supercharged...
Post #441762 17th Jun 2017 9:49am
ah, i did notice that but the info got lost on route to me sensible mind.. Embarassed ... - .- -.
Post #441763 17th Jun 2017 10:32am
GraemeS
I assume that your vehicle doesn't have ACC otherwise you would have tried disabling it. Mine's ecm is down at least 2 update levels on what's currently available so there's a remote chance that the very latest L322 s/w might have the feature.
Post #441765 17th Jun 2017 10:51am
socalengineer
United States 2015 Range Rover 5.0 SC V8 Waitomo Grey
GraemeS wrote:
Thanks Stan!
Adaptive CC can be totally disabled by removing the fuse for the radar unit then changing several CCF parameters using your IIDtool, having only recently retro-fitted ACC to my MY12 TDV8. However Stan's suggestion would be preferable although ACC might be restored on next start-up. I'm going to try Stan's suggestion as sometimes I would prefer mine's original, standard CC.
Hi,
I have an L494 and I checked the manual for the fuse box, apparently the same fuse for the ACC operates the ACE system as well. I definitely do not want to disable the ACE system because that improves the handling of the vehicle but I need to disable the radar because I keep getting an error message that the radar system is blocked (put a new grill on). I'm fingers crossed just changing the parameters in the IID tool will disable the error messages on the instrument cluster.
Any other suggestions?
Post #684819 5th Feb 2024 6:18pm
GraemeS
Was the radar unit bumped during the grille change? Maybe the radar unit needs to be recalibrated for the new grille, which could be an IIDtool function if the function exists for your vehicle.
Post #684839 5th Feb 2024 8:13pm
socalengineer
As far as I know the radar unit was not bumped during the grille change. I tried the calibration today and even during the calibration it says radar is blocked so I have a feeling it won't calibrate.
I guess my next steps is to try and disable through the IID tool with CCF functionality and not take out the fuse. Hoping I can still disable it while leaving the radar connected with fuse on.
If that doesn't work I'll try to disconnect the radar sensor, and leave the fuse on because I don't want the ACE system to stop working I need the active sway bars.
Post #684852 6th Feb 2024 2:41am
socalengineer
Okay I was able to disable the radar / adaptive cruise control / emergency braking with the IID tool on my 2015 Range Rover Sport L494 autobiography.
I was getting some parking brake errors during the process, it turns out I just needed the right set of settings, so here are all of the settings I used. I did not need to remove any fuses for this to work. I only had to do this because I had an aftermarket front bumper that blocked the grille, and I never liked that adaptive cruise control feature / emergency braking.
Adaptive speed control ECU - Unchanged - North America, Canada, Mexico, Australia
Adaptive speed control ECU - Unchanged - Standard blockage level -40dB
Adaptive speed control ECU - Unchanged - Follow mode off
Standard speed control display type - Changed - No speed control display
Adaptive cruise control indiction in instrument cluster - Changed - Disabled
Speed control - Unchanged - Adaptive speed control, stop and go (this was required to get the parking brake fault to go away)
Intelligent cruise control - Changed - Not fitted
Speed control - Changed - No speed control is fitted
Speed control - Changed - Speed control not fitted
Low speed intelligent emergency braking - Unchanged - Not fitted
Collision mitigation by braking - Changed - Not fitted
Collision mitigation by braking - Changed - Without collision mitigation by braking
Post #684897 6th Feb 2024 8:06pm
For members over this side of the pond, be careful not to copy the above otherwise your car might want to drive on tuther side of the road Whistle Laughing Bow down
Post #690866 18th Apr 2024 11:37pm
GraemeS
Australia is RHD and I haven't noticed my RR preferring the other side.
Post #690878 19th Apr 2024 8:36am
supershuttle
Mine works fine and I like it, the adaptive bit stops me running into the back of someone when I fall asleep Rolling with laughter Rolling with laughter Geoff
Post #690882 19th Apr 2024 9:03am
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
stan wrote:
that's a bummer, i'm sure i read that procedure worked... Crying or Very sad
That worked in my 2017 Sport Stan, you can only get to 1 bar in the 322 Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #690907 19th Apr 2024 12:59pm
TDV8 Paul
That’s interesting that you can’t get in with it, I’ve come from normal cc to the acc and I love it, I found that you have to read the road ahead a bit so I anticipate the car in front slowing and move out before the system detects the slower car to maintain my set speed then move back in when I can, sometimes I can’t move out as the next lane is travelling faster then the speed I’ve set so I just sit behind and wait until a gap opens then move out.
Took a bit of learning and getting used to 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #691027 21st Apr 2024 11:11am
