![]() | Home > Technical (L322) > Dealer Advice Needed |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
I've not had this issue, but did, on my last car and some time ago, have a situation where recall work led to another problem and the dealer billed me for about �1000 for fixing it. I took this up with LR Customer Relations (0870 5000 500) and had a very useful and detailed discussion on the technicalities with an expert there. I don't know whether that level of service is still available, but on that occasion I was told to leave it with LRCR and the the outcome was that I did not pay anything. Only Range Rovers since 1988 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
Thanks for that, I'm waiting for the dealer to call to say the car is ready and I'll discuss the bill with them then. The car is out of warranty so I'm not against paying something for the repair but what really annoys me is the fact that they've snapped the sensor in the manifold and the only reason they were replacing it is because they broke it in the first place.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Can you prove they snapped the sensor? That fault code may not equal a snapped sensor at the time. Equally, can they prove that they didn't? Ask to see the job card and a health check as it may be on there my the technician who did the work.
The only way I can prove they damaged the sensor the first time around is because the IID shows the date and time the fault was triggered and at that time the car was in their workshop.
Very difficult situation. Been on both sides of this. I'm an Aftersales Manager myself so have had a fair bit of similar scenarios in the past. Also been in your shoes as well.
Ask to look at the job clock times when they did the recall as that will show if someone was actually working on your vehicle at that date and time which would help you as well.
Thanks Alex.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
if I work on a car and damage another item my solution (which has always be seen as acceptable by all parties)
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 364 ![]() ![]() |
If its taken them a week then I'd put money on it being a job filler and every monkey in the workshop has had 10 minutes on it between jobs. Current
I spoke to them yesterday for an update.
