Home > Technical (L322) > TDV8 Turbo Issues? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Here's what I found from Mikey's part numbers
11th Jun 2017 9:28am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2500 |
Ensuring that the 2nd, rear-most sump drain plug is also removed at each oil change as that plug drains a reservoir into which the turbo oil drains. The reservoir when not drained can fill with sludge over time which risks inhibiting oil flow from the turbos. |
11th Jun 2017 11:39am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Cheers Sir. All nice easy answers which is appreciated on such a complex matter. Mine is in for service in next couple of weeks so I'll get the oil pipe feed replaced too. Can anyone help with an LR part number for said oil pipe feed. Is this where I put the car details and a bit about myself ?........ |
11th Jun 2017 1:26pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
LR006644 |
11th Jun 2017 2:58pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Any vehicles fitted with turbo(s) should be 'simmered' after a hard run.
12th Jun 2017 10:07am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 |
You're right Nick, Mikey is the turbo guru! I know 2014 vogue se |
13th Jun 2017 7:29am |
I did note your 'issue' and Mikey sorting it
13th Jun 2017 7:59am |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 |
Mikey, thanks for these tremendous turbo tips
13th Jun 2017 11:11pm |
This is an interesting perspective on 3.6 turbo related motor failure.
16th Jun 2017 11:33am |
Interesting, but I wonder how much it costs? |
16th Jun 2017 3:33pm |
Actual time taken, I can't remember
16th Jun 2017 8:28pm |
Nespouls Member Since: 06 May 2017 Location: Terrasson Posts: 24 |
Could I ask for turbo advice, please - - after barely two years of owning my TDV8 I am suffering early onset FullFat anxiety.
28th Jun 2017 12:13pm |
Wouldn't be worried at all
28th Jun 2017 7:24pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Second what Mikey says, I changed my EGR valves and had lots of sutt to clean out of the pipes and throttle body. The second sump plug only holds a small amount and is to get rid of any sludge. Just clocked 134k on mine, I change oil and filter at least every 8K to keep it all clean. |
28th Jun 2017 8:05pm |
