Home > Technical (L322) > - Help Removing the lower facia shroud problem
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I am in the process of removing the padded lower fascia shroud, I have it all disconnected it is free everywhere except above the glove box.
At the glove box end it is stock under the Passenger air bag panel. Is there retain screws under the airbag panel or is it just clipped in. Rave mentions clips and torx screws holding the lower fascia panel on, but is not real clear on removal procedures.
Thanks in advance
Post #440934 8th Jun 2017 5:18am
lounge_on_wheels
Problem Solved, a sharp pull was needed to remove, it is hels on by clips and plastic tabs under the airbag part of dash.
Post #440938 8th Jun 2017 6:48am
