Home > Technical (L322) > Reversing lights
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Reversing lights
2012 4.4 Westminster, just noticed that both ( do they have 2 ? ) reversing lights have gone out, is there anything technical I should look at before replacing the bulb(s) ?
Thanks
Jeff I need more help than most...sorry !!
Post #440762 6th Jun 2017 6:01am
replace the bulbs and see what happens Jeff, or if you need them brighter then replace with led cob panels.. ... - .- -.
Post #440763 6th Jun 2017 6:03am
muppet
will do Stan, and will be sticking to traditional bulbs as not technical enough to start changing things... Crying or Very sad
Thanks I need more help than most...sorry !!
Post #440764 6th Jun 2017 6:34am
nino_nino
muppet,
Bosh makes 10W halogen bulbs, which are quite a bit brighter then factory 6W and thay are safe for the plastic housing.
Post #440807 6th Jun 2017 3:24pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
These are the 10w ones I used and they are better than standard. Not a lot, but better.
http://www.ebay.co.uk/itm/160858588020?_tr...EBIDX%3AIT 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #440820 6th Jun 2017 4:40pm
muppet
Thanks for the replies and info, greatly appreciated.... I need more help than most...sorry !!
Post #440843 6th Jun 2017 8:03pm
