![]() | Home > In Car Electronics (L322) > Digital Speedometer |
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 ![]() ![]() |
You can enable the digital speed readout with an IIDTool - so that the main speed readout is in MPH, as is the digital one |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
You can enable a digital km/h reading in the centre of the normal mph dial without the IID tool. Simply go into the settings and change the units for the trip computer to km instead of miles. It will then appear. Useful when in Europe with speed limits in km/h and quick and easy to revert on returning to the uk. Current: 2010 Range Rover L322
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
i think means have the main dial in kph and the little digital in mph so you can compare the kph to what you're used to here in the U.K..
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
I meant like this:
you cant do what you have in you pic scot...
Im gonna look further into the firewire hack.. this way I should be able to update the map too..
if it was possible to load igo primo on the hard drive that would be awesome... ... - .- -.
now we are talking.. drooling over it already
the iidtool aint cheap but its worth its weight in gold...
cheers will do on Monday.. roughly how much are they? Current:
the bluetooth one is around £400... ... - .- -.
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
is there a downside to having an IIDtool, does it invalidate any warranty or cause issues in an insurance claim IE car mod etc....has anyone ever had issues where it has been difficult to revert back after changing a settig etc...
I don't suppose it voids any warranty. The prime purpose is to diagnose a fault.
the GAP iidtool cleverly saves all the original settings on activation so if you mess up (and you will |
