![]() | Home > Technical (L322) > Air Conditioning Condensor TDV8 MY07 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
the td6 condenser is at the front so it gets loads of damage from stones etc, i gather yours must be in the same location..
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
Workshop manual just says move oil cooler and fuel cooler unbolt et voila, lacking in how do you actualy get in there to start with. Through the front / back ?? Took the grill off and all you see is fan and covers. No doubt grill off headlights and surrounds out, slam panel off would seam the obvious way in to me but some reading I have done says engine fan and cowl and take the radiator out first. If everything is under control you are not going fast enough.
Well as no one on here had any ideas, I went in blind and yes you can get at it all from the front of the car but you do have to take a lot of car off to get at it all. Not a problem fairly easy as long as it is taken step by step.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle MY 12 Full Fat TDV8 1952 Series 1 80" 3ltr 6cyl |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Well done. |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Looks much harder than the supercharged. I only needed to remove the slam panel and ease the condenser out! |
2006Rangie Member Since: 26 Jan 2017 Location: Toronto and Melbourne Florida Posts: 22 ![]() ![]() ![]() |
This looks like a phenomenal amount of work.
If it's anything like the 4.2 (it should be), the A/C condenser can be removed carefully upward without removing radiator or disturbing coolant hoses. You will need to remove the front slam panel (not difficult really). There should be some threads around describing the procedure.
I read your write up from 2 years ago. I have the same issue with the pipes connecting to the condenser. I was able to remove both bolts after a few days of coaxing with PB Blaster, but the clamps seem to have fused to the connecting block of the condenser; they won’t budge. I am reluctant to cut the pipe as you did, so have been fiddling with it for a few days. Today, I tried to score the clamp/block interface with a knife and sprayed PB Blaster at the interface to see if that might penetrate into the joint. I am running out of time to get this blasted condenser out as I have to travel this weekend and need the car back into operation asap. Is there a dowel in the clamp? If I can use a vise grip on the clamp, I might try twisting it to break any aluminum to aluminum corrosion. Darn, this job was really to change the compressor but I extended it into a mini overhaul of the system by replacing the compressor drive belt, tensioner, and the condenser. Any ideas for a non-destructive way of separating the condenser from the pipes? |
As I recall I think there was a dowel there, yes. I gave up at the bolt stage, the replacement pipe sections were not ruinously expensive - it was just easier.
Yes, I confirmed that there are dowels after I had posted the question. I wrestled with it again today and it is showing the tiniest signs of movement across the joint but it will still not come apart.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
just put your dessicant in the oven for a few hours to regenerate |
Would love to do that, but the existing condenser (and the new one which is a Nissens) both have the access plug at the bottom of the condenser rather than the top where the manual shows access of the OE.
Strange, the receiver dryer was integral with the condenser unit on mine. |
It is integral. It is a vertical cylinder about 40mm diameter full height of the condenser on the opposite side from the high- pressure pipe connection block. The problem is that they put the insertion cap on the bottom of the condenser instead of on the top.
