Home > Technical (L322) > urgent help needed. what parts required?
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
Hello all,
I have to replace the turbo on my FF.
I have received the replacement turbo, but it didn't come with any gaskets.
I have been trying to find which gaskets are needed, but I cannot find the exact gaskets.
Has anyone done this? If so, can you let me know which gaskets I will need to order?
I obviously need the two gaskets for the turbo, but do I need any others?
Can the turbo be removed from below, or do I have to remove from above?
Thanks for your help!!
Nick
Post #440576 4th Jun 2017 9:02am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Before anyone will be able to help, you will need to tell what car you have. The answers to your question will vary, depending on the engine you have. You can add details of your car to your profile. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #440582 4th Jun 2017 9:26am
nebc100
Sorry... For some reason if isn't showing up in my profile even though I have tried updating it several times!!
I have a 2003 td6.
Post #440583 4th Jun 2017 9:28am
nebc100
Does no-one know the answer?
Would a gasket kit for a BMW x5 have the right gaskets since to my knowledge it used the same engine.
Post #440605 4th Jun 2017 12:28pm
ask dan @ duckworths for a quote .... ... - .- -.
Post #440619 4th Jun 2017 1:35pm
