Home > Maintenance & Mods (L322) > Diy oil change. |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
My manual says use 934 but you can use 1 L of 913 in an emergency |
2nd Jun 2017 5:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
no point in spending the extra on the 934 as its for the 4.4 not the 3.6.
2nd Jun 2017 5:28pm |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 |
I got the correct spec oil from euro parts and I think there's an offer on again this weekend so worth checking out the website. 2009 Vogue SE Zermatt silver |
2nd Jun 2017 5:33pm |
My bad (4.4 owner) |
2nd Jun 2017 6:05pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
I have a 57 (08 MY) 3.6 tdv8 which was the year they introduced an optional DPF which my car has. Even though the manual says A1 spec Ford 913-B oil I believe that if your vehicle has a DPF you should be using a C3 grade oil to avoid potentially damaging or reducing the lifespan of the DPF. My independent LR specialist backed this up when I spoke to them recently and they were adamant that a good quality 5W-30 fully synthetic oil is a must for the 3.6 TDV8. I will be using Castrol Magnatec C3 grade oil which I can get from Costco for around £25 for 4 litres. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
2nd Jun 2017 6:52pm |
Mines a 2009 model 3.6. How would I know if it has a dpf or not? 2009 Vogue SE Zermatt silver |
2nd Jun 2017 8:00pm |
Look underneath the body at the front seats area. If there are large 'canisters' in each exhaust pipe with quite small pipes coming off the main pipe before and after the canister then you have dpf. There are also heat shields attached to the canisters. They are each side of the auto box. If the pipes are simple pipes then you don't. I think ( can't remember exactly) that after 2010 MY dpf was standard. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
2nd Jun 2017 8:20pm |
Thanks I'd better take a look tomorrow. There's no mention of dpf in my handbook and no sign of a dpf regeneration light on dash etc. 2009 Vogue SE Zermatt silver |
2nd Jun 2017 8:58pm |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 |
Hi I used one of these on my 4.4L tdv8. I then removed the sump plug that's above the cross tube. (My engine only has one sump plug). Next to nothing came out. I used a reducer air coupling to connect the white plastic tube to the oil removal tube. Cheers Ian LandRover 90 1985 300 Tdi Auto, Epsom green LandRover D1 Premium 1998 300 Tdi Auto Rioja red LandRover F1 2004 Td4 HSE Auto Giverney green LandRover FFRR Vogue 20114.4L Tdv8 Fuji white |
9th Jun 2017 6:40am |
I found out the one I've used for years on all my cars only has a 8 litre capacity..... emergency air release required |
9th Jun 2017 6:49am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
This is my, 12 L capacity,
9th Jun 2017 7:40am |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 |
These pumps seem popular but I am not sure I am converted. The first time I drained both plugs on my (recently sold) 3.6 at 95k miles, a cup full of thick sludge came out of the rear plug. Car had a full dealer history when I bought it so suspect a pump had been regularly used. Over the next 40k miles and 4 changes, the rear plug drained freely and was not that messy using a cardboard funnel. It left me wondering if I would have faced and expensive turbo failure had I not properly drained the rear of the sump.
9th Jun 2017 4:40pm |
its a common dealer cheat.
9th Jun 2017 5:10pm |
