![]() | Home > Maintenance & Mods (L322) > fan shroud 4.2SC |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Stu, If the same as mine 4.4. There is a small screw / bolt half way down on the right hand side & further clips at the bottom. You will need to undo the the lower shields as well. *** what ever you do don't yank it out, as there are connections on the bottom.
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
thanks Hr, I'll look underneath and at side, bit more involved than I first thought |
