Home > Technical (L322) > How quickly can fuel go bad? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
It takes a while to gel - but it could get contaminated almost immediately I guess...... |
25th May 2017 7:06pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
Modern petrol in a sealed container will last for a considerable time - possibly years. The problem is when its put into a cars fuel tank which is vented to atmosphere. Then most highly volatile components in the petrol will tend to evaporate over time. As they do, the remaining fuel's volatility and ability to combust properly will degrade. The less volatile the fuel, the less effectively it burns in your engine. The result is diminished engine performance. Your engine may still start and run, but it probably will lumpy and keep cutting out until the engine has heated up. Ask any lawnmower owner who doesn't drain their fuel tank at the end of the season and then struggles to get it going the following spring.
25th May 2017 7:51pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I agree.
26th May 2017 7:48am |
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 |
Fuel will go bad over 3-6 months. But bad is a relative term.
26th May 2017 9:57am |
Oh and should have said, get some easy start and spray in the intake, if it does not start with that its not a fuel issue. If it does start keep spraying for say 10 secs, once every thing in the carb gets wet it may run on the petrol.
26th May 2017 10:01am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Thanks for the food for thought gents. TBH we have tried everything inc retarding advancing etc etc and bad fuel is really the last option.
26th May 2017 11:19pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi ,
27th May 2017 8:20am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Interesting, as I've had issues with fuel causing starting issues on my classic cars after about 3 months.
27th May 2017 10:38am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I have a classic and p38 in the garden neither have been on the road for nearly 4 yrs I move them about once every 6 months neither has had new fuel added and both start after a couple of turns - my guess is water in the carb good luck be interesting to see what the outcome is |
27th May 2017 12:16pm |
Well new fuel made not a bit of difference although she seems to want to start better if that makes sense.
29th May 2017 11:12am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Have you checked the compression? |
29th May 2017 11:21am |
Know it sounds daft but the leads are on the right plugs had a similar issue when replacing coil packs on p38 got in a right muddle and plugged it all up areas about tit
29th May 2017 11:36am |
Riedland Member Since: 06 Oct 2015 Location: Far east Posts: 21 |
You mention it's a restoration project, what did you do to the engine? Is the ignition set right? Sounds as you had not the sparks at the TDC. Current: - L322 2006 S/C lpg - RRC 1988 lpg / 287 000 miles - Stage one 1981 - Lightweight 1976 - 109 SW 1968 under rebuilt Gone: none |
29th May 2017 4:44pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
I would take all the spark plugs out and let it stand overnight, it may be flooded, or take the FI fuse out and crank.
29th May 2017 6:50pm |
