Home > In Car Electronics (L322) > ignition feed
handyM
England 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
ignition feed
Hi can anyone tell me where I can pickup a ignition feed for a camera monitor at the front and
a ignition feed at the rear for a reversing camera
Post #439446 24th May 2017 3:06pm
do your ciggy sockets power off when you lock your FF?
if so, tap into those.. ... - .- -.
Post #439447 24th May 2017 3:20pm
handyM
Hi Stan
thanks for your reply but the cig sockets are 12 volt permanant
Post #439448 24th May 2017 3:33pm
you can change them to ignition feed by replacing the relay, do a search, theres info on that somewhere on the forum..
also, search dashcams or look in the wiki, it might give you some ideas.. ... - .- -.
Post #439449 24th May 2017 3:36pm
handyM
Thanks Stan
I will look the info
Post #439451 24th May 2017 3:42pm
The ignition feed in the rear is in the offside compartment.
If you look in the harness above the fuseboard you will find a1mm2 green/yellow cable. Thats it.
I would suggest tracing it to the rear of the car to find a siutable point for splicing in.
I strongly recommend you use the wire to feed a relay and take a feed for your camera from the rear fuseboard Thumbs Up
The best way to get an ignition feed in the front is to use a piggyback fuse holder plugged into the front fuse-board into an ignition fed circuit. Thumbs Up
Post #439456 24th May 2017 4:05pm
