Home > General > Should I wait or should I get a refund?
SteveRRL322
Hi,
I have had my 2007 TDV8 for about 6 months and have only covered about 2000 miles and it is now with the
Supplying garages Land Rover expert who is trying to find a coolant leak. They have had it for 6 weeks and cannot
Find it they have checked all usual places but nothing. They are now removing the body and stripping the engine to look at waterways etc.
I have asked what if they can't find it what then and they have said a refund.
So seeing as I think they have had long enough do it get a refund and have a look around again. 2010 models are now under
15k it seems or wait to see if they fix it. I really like the car and it is exactly what I wanted and have spend about 1k on
Servicing and bits and pieces which I won't get back I expect. It also has my Private plate so messing about there.
What do you guys think.
Thanks Steve
Post #439157 21st May 2017 3:42pm
pld118
If you hope to have matters resolved and to keep the car:
Select an independent LR 'expert' that you have been recommended to use; and get the indie to assess the car at the cost of the supplying garage. See what said indie says, then take stock and take it from there...
Post #439164 21st May 2017 5:50pm
SteveRRL322
Thanks for your reply.
But those face lift 2010 do look good inside and out!
Post #439171 21st May 2017 6:44pm
GGDR
Sounds like you've already made your mind up!
. Cheers, Greg
Post #439177 21st May 2017 7:18pm
SteveRRL322
Maybe 😁
Just out of interest what are the changes from a 2007 to a 2010 apart from the interior
And the front end?
Post #439199 21st May 2017 8:58pm
