![]() | Home > Technical (L322) > Odd air suspension problem |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 ![]() ![]() ![]() |
Just a guess but have you checked the ride height sensor on that corner? Rehab is for quitters!!!
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Hi. I haven't no. What should I be looking for? I changed the wheel on that corner a few days ago, although have been having problems with that corner for weeks. I noticed there was a plug with nothing in it and wondered should there be anything in it?
Ok something interesting has just happened. I drove the ff onto our flat concrete level yard. I pressed the ride height inhibit switch and the rear wheel came to it's correct height, I think the front left moved sown a tad too. Now it all seams to be working and has not faults showing on the dash. |
I's run it up to maximum height then drop to access height a few times and see how it performed. Rehab is for quitters!!!
I've thought about doing that but now am worried if I do it will mess it up again lol. The troubles started when I put it on maximum height a few times to do work underneath it. |
Thought I would just update this thread.
