Home > Technical (L322) > Steering column lock on 10MY+
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Do the late models with keyless start still have a steering column lock that engages when the motor is switched off? Or was this only on the models with a mechanical ignition? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #439020 20th May 2017 1:11pm
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Mine (MY10) has no steering lock. I'd imagine having no steering lock is a safety feature on cars without a mechanical ignition?
Post #439041 20th May 2017 4:22pm
FrankRizzo
Cheers, good point Thumbs Up 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #439042 20th May 2017 4:27pm
Steve67
i'm sure they do. After switching off the engine if you wait until the the display goes off you can hear a mechanical noise as the lock engages.
Post #439047 20th May 2017 5:30pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
My 2011 has a lock after I turn off, no idea how it works though.
Post #439052 20th May 2017 6:00pm
GraemeS
I disabled my MY12's steering lock, not trusting the electronics to determine if the vehicle was no longer in use after learning about a MY07 when its alternator failed and rapidly discharged the battery. Not key-less but it still locked the steering whilst the key was in the ignition switch in the ignition-on position. I can't see any advantage in having steering locks in modern vehicles.
Post #439069 20th May 2017 8:35pm
FrankRizzo
Unnecessary quote removed
Wow, the alternator failed in my 08MY a couple of years back so I guess I'm lucky that didn't happen to me. Steering the thing without servo assistance was still hard enough, though Laughing 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #439090 20th May 2017 11:05pm
