![]() | Home > Maintenance & Mods (L322) > Checking Gearbox Fluid Level |
Whilst flicking through RAVE I found that when checking the gearbox oil level there is a narrow temperature range where this must be done for both the Petrol and the Diesel.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I thought they were 'sealed for life' units? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
They are sealed for life of the warranty, as far as LR is concerned thats all that matters. A mechanical device cannot sit in its own filth and continue to work indefinitely! ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
so hows the level checked dan? ... - .- -.
With the level plug... ![]() |
As your gearbox doesn't live in the engine compartment - I'd say no. It's a fill/level plug so you stick some oil in through the same hole - when it starts dribbling out its full. Can only really be accessed suitably when up on ramps. Dan ![]() |
thanks .. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I did a gearbox filter and oil change before the winter. easy job but first time took a while. the fill/level plug is easy enough to access if you want to top up or check the level. i did mine with the car in off-road setting and had enough room. |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
You are supposed to check the gearbox oil when engine is running though, in neutral. I don't fancy doing that lying under it! When I flushed mine, I forgot the "engine running" bit and lost a fair amount up my sleeve... |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Life means 100,000 miles so far as ZF and Land Rover are concerned. That's why they have the limit on their warranty mileage 2012 SDV8 Vogue SE |
ZF Revised this figure to 60K for the 5 speed. Due to failures when the oil was left longer than that. The 6 speed is pretty much the same gearbox internally, except it has an extra gear in it, the extra gear wont add 40k to the life of the oil... Land Rover don't want to change your oil - if you need a replacement gearbox at 120K then that's a bonus for them because you'll be out of warranty. It's not a conspiracy theory, its just how it is. ![]() |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
Automatic Transmission/Transaxle - 4.4L NA V8 - AJ41 - Transmission Fluid Level Check
