Home > In Car Electronics (L322) > Navigation ECU Connection Questions.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Looks like my GPS antenna has expired (I've done the '753' hidden menu thing). As I understand it's in the roof fin (2006 Vogue SE).
As I also understand, it's a FAKRA connection to the GPS antenna. Can I just plug an aftermarket GPS puck with a FAKRA connection into the loom by the roof fin? A magnetic one will just stick to the roof under the head lining.
I have been unable to find an image or diagram of the rear of the Navigation ECU showing the various connection ports, so can I just plug the FAKRA GPS puck directly into the Navigation ECU? Or is this far too simple a solution for LR? Very Happy
Post #438859 19th May 2017 5:24am
have a look in the wiki, there's info on replacing the sat nav antenna.... ... - .- -.
Post #438861 19th May 2017 6:07am
Gyre8
Thanks, yep. Just found this thread which gave me most of the info I need.
http://www.fullfatrr.com/forum/topic17777.html?highlight=fakra
I may just stick the aftermarket GPS magnetic puck to the roof under the headlining to save fiddling with adapting the roof fin.
I think this would work.
Post #438862 19th May 2017 6:25am
