![]() | Home > General > Can't turn ignition key |
Are you certain the batery is now fully charged? The key wont turn if there is no charge left in the battery because there wont be enough juice to power the key lock. |
nielsen Member Since: 26 Aug 2010 Location: Sweden Posts: 7 ![]() ![]() ![]() |
The batteri is absolutely drained. Will I be able to turn the key if I attach jump cables from another car? Regards,
Yes.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I thought the gear selector was locked until the key was in... more I think about it more I confuse myself and I got up too early today to go back out and check again.
He put the car in N first, its only now that the battery is completely flat he cant get the key to turn.
I get what your saying Dan.... but why would putting a fuse in make and difference if the battery were dead |
What I'm trying to get at is Do Not Tow the car without following this procedure to get the transfer box into neutral. If you cannot do this because there is no power then do not tow the car. The cost of a new transfer box greatly outweighs agro of running an extension lead to the car. Although in reality the chances of causing damage over a short distance is negligible. ![]() |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Absolutely agree about the transfer box.
One learns something new every day!
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I'm not sure if there is one on modern Range Rovers, but the old style mechanical steering lock hasn't engaged has it as if it has then the key won't turn and the steering wheel won't turn either. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
I got the car running again late last night. Had to buy longer jump start cables first and needed a bit of help from my neighbours Volvo. He really had to floor it to generate enough power to get her up and running |
Peter, there have been a lot of posts about flattening batteries and replacement batteries recently - IIRC Fox bought and fitted a Varta or a Bosch - if you use the search then you may find it turns up a lot of recommendations about what the battery specs are and which ones people have found best. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Battery short code for diesel is I1 - Varta of Bosch are excellent. |
