Home > Maintenance & Mods (L322) > Front and Rear differential oil for L322 V8, 2003 model
Zain
just need to double check that i can use Castrol Syntrax Longlife 75w-90 in both the front and rear diff for the oil change?
Any tips on doing the oil change?
Do i need to buy/replace any washers on the drain and fill plugs?
cheers.
Post #438702 17th May 2017 4:36pm
theres some info in the wiki that might help.. ... - .- -.
Post #438703 17th May 2017 4:58pm
pld118
This workshop manual link should help and it advises what oil to use:
http://workshop-manuals.com/landrover/rang...fications/
Then, this link is a long running changing diff oil thread that will also help. It is straightforward to do:
http://www.fullfatrr.com/forum/topic29093....p;start=45
Post #438706 17th May 2017 5:13pm
Zain
thanks for the replies guys......
Wiki states that the front diff take Castrol SAF X0s 75w90 (which is now rebranded as Castrol Syntrax Longlife 75w90) and the rear diff takes Castrol Carbon 75w90.
So do i use two different oils or is it ok to use Castrol Syntrax for both front and rear diffs as they both have the same temperature range viscosity?
Post #438744 17th May 2017 10:11pm
kbald
The castrol carbon is used if you have the electronic locking rear diff I beleive. If its the normal one its the same oils from and back. Current 2007 TDV8 Vogue Buckingham Blue
Post #438753 18th May 2017 6:47am
Dave 67
England 2004 Range Rover Vogue 4.4 V8 Java Black
I also have an L322 V8 2004, checked with dealers and I was informed no electronic diff at that age so same oil front and rear diff. 2004 4.4V8 Vogue
BMW 330CD
BMW523i
Escort Mexico MK1
1974 airportable series 3
Post #438776 18th May 2017 11:40am
