Home > Technical (L322) > Heated wheel
Rewmer
Heated wheel
Ive been trying to get the heated wheel going on my 2003. Previous owner fitted a piano black wood n leather one with flappy paddles. It looks like I have power upto the ecu and bench testing the wheel it gets warm with direct current applied to the heater circuit . I am not getting any light on the button though. I changed out the ecu for another but stlll nothing. Does it have to be switched on in the CCF ? I have IID BT but couldnt find any listing for it???? No7 - 2003 V8 Vogue
Post #438372 14th May 2017 5:17pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
If it has flappy paddles, then I am guessing it's a recent wheel (maybe post 2010) so could it be that it's not compatible with the ecu in your rangie? Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #438378 14th May 2017 6:51pm
mjdronfield
Do the flappy paddles work? There is a reluctor ring behind the wheel that is used to feed the signals back from the steering wheel buttons. There is not a ring free for the paddles to use so a previous owner may have used the feed from the heated wheel ring instead - hence heated wheel not working. Could be wrong - just a thought.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #438386 14th May 2017 7:16pm
Rewmer
I.ve good experience of the flaps having retro fitted them to my x5. They are not connected at all. All other switches work ok. No7 - 2003 V8 Vogue
Post #438388 14th May 2017 7:27pm
mjdronfield
I fitted a new soft napa leather wheel to my 2003 TD6 and used the new control unit that was with the wheel - the one that's in the wheel if that's it...had no issues. Wouldn't have thought it had to be configured as your car would have had it fitted as standard.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #438392 14th May 2017 7:42pm
Rewmer
18 months later and I’m still at it. Plumbed in a new feed to the back of the clock spring and we have heat ! Trouble is it’s permanently on. I don’t have a light on the button either. I’ve tried another ecu and another switch and still the same. No7 - 2003 V8 Vogue
Post #495031 8th Nov 2018 4:46pm
