![]() | Home > Maintenance & Mods (L322) > ZF6 gearbox leaking mechatronic sleeve |
I had this changed by the garage, along with fluid as you describe - then when driving home I got trans failsafe etc. The plug had worked loose.
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Apparently this can happen. This is a wild guess, but if garages have the same issues as I did putting in a new sleeve, I wonder if they try to get away with one of :
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Is the mechatronic sleeve leak particular to the zf6 or can/does the zf 5hp24 suffer from the same problem?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
The 5HP24 doesn’t have a separate sleeve because the electrical connector plug is part of the internal wiring loom. The connector plug does have two O-rings on it (they’re coloured white in the photos) to seal the inside from the outside but they generally aren't problematic like the earlier (orange) 6HP26 seals. You don’t therefore need to worry about this.
Phil...as ever...thank you for the informative detailed reply.
Biggp Member Since: 15 Aug 2020 Location: Dunfermline Posts: 7 ![]() ![]() ![]() |
I,m having gearbox issues It had a flush and oil service about 8 weeks ago and I have been getting the odd transmission fault appear on dash in particular when on motorway when accelerating to overtake then this happened.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
What codes are stored in the engine system? |
