Home > Technical (L322) > Suspension set up
stu
Suspension set up
Hi all, I have been frantically reading and searching through lots of suspension threads, doing lots of input. What I'd like clarity on, is with the latest version of the IID bt tool, if I want to check my suspension set up, does it still have to be on level ground, as my drive is on a slope. I tried to measure with a tape this morning, but everything was different on all four corners!
Any top tips from those who have done this would be helpful. I guess once I've done it things will be more apparent. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #438347 14th May 2017 12:48pm
Yep, you will need to be on level ground to get best results, then you can calibrate successfully, car will try to level itself out otherwise, giving you incorrect readings. .
Post #438352 14th May 2017 1:37pm
stu
Thanks joe90.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #438354 14th May 2017 2:40pm
