Home > Technical (L322) > Just bought a car all was fine for the first 40 miles...
dingg1
I bought both from ebay but the first was listed as being for my car , it wasn't , they change part numbers and resistances a couple of times , the fronts are different to the rears , ones for diesels are different to the petrol models , the bmw ones may be different to the jaguar ones ( I'm not too sure on this one) best bet would be to give a main dealer a call with your vin number and confirm part number and take it from there Or you could check the resistance on the new one against the one from the other rear wheel sensor IF you get it out without breaking it
My monies on you having been supplied the incorrect sensor though , cheap fix if so
Good luck
Post #437716 9th May 2017 6:34pm
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Hope so.
Might even bite the bullet for one direct from LR if it saves on fault finding. It'd be cheaper in the long run.
Is there a website, like realoem.com for BMWs, that gives exploded diagrams and part numbers based on your VIN? Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #437717 9th May 2017 6:51pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Microcat if you navigate the bits in Russian!
http://lrparts.ru/engl/ Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #437723 9th May 2017 7:08pm
Keith A
Brookswell parts are just up the road from my work.
Would you recommend?
http://www.brookwell.co.uk/products/RANGE_...sor_-_Rear Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437744 9th May 2017 7:53pm
Keith A
Just checked my ebay order.... I have bought the wrong sensor Laughing
http://www.ebay.co.uk/itm/332187414822
In my defence it was listed as upto 2012. Hadn't realised that there were further differences!
I take it I need part no: SSF500021 Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437757 9th May 2017 8:05pm
GraemeS
That's the correct number according to my English version of Microcat for a MY09 TDV8.
Post #437767 9th May 2017 8:34pm
Keith A
Thank you. Hopefully I can pick one up tomorrow. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #437768 9th May 2017 8:38pm
dingg1
You're not the first lol
Post #437770 9th May 2017 8:41pm
Keith A
Correct sensor fitted and hallelujah! Fingers crossed it stays this way.
On the down side the repaired rear camera failed again tonight Laughing
Already ordered a replacement fleebay one earlier in the week, hopefully get it this weekend. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438063 11th May 2017 8:13pm
L_Ashman
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Glad you got the sensor sorted Keith. Thumbs Up
Have you gone for an identical replacement camera or something better?
Post #438151 12th May 2017 12:10pm
Keith A
Just the one that was recommended in one of the threads on here.
http://www.ebay.co.uk/itm/141918317810?_tr...EBIDX%3AIT
Going to fit it shortly.
This might be why the parking sensors weren't working either:
 Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438154 12th May 2017 12:39pm
Keith A
Parking sensors now working.
They sent a PAL camera instead of a NTSC one. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438177 12th May 2017 3:39pm
