Home > Technical (L322) > Coils pack
alistairh
Coils pack
I've recently done my cam gaskets and since putting it back together I've had a slight surge in the engine and the exhaust is puffing? Anyway checked new plugs are seated correctly and there fine.. I then tried pulling each coil pack out with the engine running and each one when pulled gives the engine a change in rpm as expected. Number 8 isn't.. no change in engine tone or rpm when it's unplugged.. could a bad coil pack cause my symptoms? .
Post #438009 11th May 2017 1:57pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Or a bad plug.
Check for issues with your IIDtool. If it was me I'd try the cheaper option first Very Happy ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #438012 11th May 2017 2:07pm
alistairh
No faults on the iid tool, I would have thought it would have shown something. Plugs were new a month prior to doing cam cover gaskets and were fine although they did get covered in oil from the leak and I cleaned them off.. possibly the electrical contact cleaners fouled the plug? I'm hoping the puffing from the exhaust is related to the plug/ coil 👍
Post #438015 11th May 2017 2:20pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Swap the suspect coil to one of the other cylinders and a known good one to the suspect cylinder. If the fault moves cylinder you can narrow it down to the coil.
Post #438031 11th May 2017 5:10pm
alistairh
Swapped the coils and problem persisted, changed the spark plug and it's fixed.. new plug had only lasted a month and died.. nice cheap fix so happy with that.. thanks for input gents..
Post #438178 12th May 2017 3:39pm
kezbo1981
Good to hear!
Post #438186 12th May 2017 5:11pm
UK Marine
Pleased it was just a bad plug. My grandad used to say start with the cheaper option first and he's been proved right quite a few times bless him.....
Regards ______________________________
Simon
Post #438192 12th May 2017 6:01pm
