Home > Technical (L322) > IID questions
phat_dogg
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
IID questions
Hi Guys,
Recently bought a GAP iid tool and just have a few things that I am trying to work out.
1. I have activated the auto locking when you get to a certain speed, but when I stop and want to get out, all doors but the driver's door will unlock when you pull the handle. For the driver's door, I need to press the unlock button near the air con vents. Is there any way it can unlock when I pull the handle?
2. Is there any option to have the blinker/indicator flash 3 times when I momentarily press the stalk?
3. I have the following faults 0x68 Steering angle sensor ECU internal fault and 0x5A Temporary system deactivation. Do I need to replace the steering angle sensor for ABS to work again.
4. I have the following faults 0x30 air quality sensor line fault and 0x1E Auxiliary water pump driver fault. I don't care about the heating after the car is off, but the air con doesn't blow hot air at all. Would this mean I need to replace the aux water pump for the heater to work like normal?
Looking forward to your help!
Post #437801 10th May 2017 1:00am
fill your car profile so we know what you have... ... - .- -.
Post #437807 10th May 2017 7:41am
phat_dogg
Sorry mate, profile now updated
Post #437943 11th May 2017 5:49am
the first question is due to a broken cable from the inside handle to the door lock, for the second you can go onto the GAP site and select your FF from the drop down menu and it will tell what's configurable ..
clear the faults and check again but if yours is working ok then don't worry, i get fault errors reoccurring and they don't affect anything.. ... - .- -.
Post #437944 11th May 2017 7:06am
