Home > Off Topic > wiring a switch help
can someone with the knowledge help me wire up one of these switches please,
one circuit with on/off
and,
second circuit with two separate feeds/inputs with one feed/output ... - .- -.
Post #437867 10th May 2017 2:59pm
Martin
Site Admin
Yep.
The terminals are split into two rows of 3, each row being a "pole" or set of contacts.
So on one side, use the middle terminal, and one of the outer ones. This will give you on/off.
On the other side, middle terminal is feed out, and the outer ones are your inputs.
Post #437868 10th May 2017 3:27pm
Martin
Site Admin
On the on/off side, use 1 as "in", 1A as "out".
Other side, use 2 as "out", 2A as first feed in, 2B as second feed in.
Post #437869 10th May 2017 3:29pm
so when its 'on' both 1 and 1a will make a circuit and both 2 and 2a will do as well..
when off ,then 2 and 2b will make a circuit? ... - .- -.
Post #437872 10th May 2017 3:44pm
Martin
Site Admin
1 and 2 are in the middle on each side (look at the side of the switch in your pic) Thumbs Up
Post #437873 10th May 2017 3:45pm
Martin
Site Admin
Feed #1 and "OUT" on 2 are connected in the "ON" position.
Post #437874 10th May 2017 3:48pm
like this martin? ... - .- -.
Post #437875 10th May 2017 3:51pm
Martin
Site Admin
See my pic Wink
Post #437876 10th May 2017 3:52pm
beat me to it.. Laughing ... - .- -.
Post #437877 10th May 2017 3:52pm
thank you boss Wink .. ... - .- -.
Post #437878 10th May 2017 3:53pm
Martin
Site Admin
No worries
Post #437879 10th May 2017 3:53pm
