Home > Technical (L405) > Thump when pulling away
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Just trying to get to the bottom of one of the noises the car makes to see if it's a problem or normal...
Here's the pattern: get in the car, shut the door and hear the deployable side steps closing. Start the engine and drive off. A few seconds after driving away there is a single thump sound which seems to come from right at the back of the car - it's not a dissimilar sound to the side steps but it's not the same. It's almost like it's something else folding away but I can't for the life of me think what it is.
Final resort - could it be the suspension coming out of access height?
Thanks for any thoughts & clues. 2016 SDV8 AB
Post #435675 23rd Apr 2017 1:53pm
WillyT
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
I get the same - sometimes notice it, sometimes dont.
Think its something to do with the boot up proceedure - dont think its anything to worry about. Previous
MY17 SDV8 SE Carpathian Grey, Black Pack, Ebony / Ebony Interior
MY15 SDV8 SE Causeway Grey, Black Pack, Ebony
MY09 RRS
MY06 RRS
Current
2007 TD5 Defender - Owned since new
Post #435735 23rd Apr 2017 8:15pm
AMTony
When the car is locked and you open one door, check and see if both sides of the car has its steps down!
I have an issue where this happens only after the first go when the car has been locked. If it is unlocked the steps operate independently as they should.
Can you report on findings?
Post #437407 7th May 2017 8:01pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
I have this. Sounds like it's from the left rear. I assumed it was diesel slap in the tank has been reported elsewhere on these cars. Does this sound like the same ? Only really hear on start up as I drive down the drive. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #437578 8th May 2017 7:12pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
What about the handbrake auto releasing?
Post #437583 8th May 2017 7:17pm
RR2008HSE
X2 Was thinking the same.
Post #437596 8th May 2017 8:20pm
AMTony
Had similar noise, like steps retracting.
I actually found out what it was - it was indeed the passenger step retracting. This is only when the car is set to single press total unlock.
All sorted now.
Post #437599 8th May 2017 8:34pm
ABAB
In my case it's definitely not the steps retracting. The steps take about a second to move whereas the sound I'm getting is a single, deep, muffled thump of a noise.
I've tried applying and releasing the EPB whilst in situ and it's definitely not that sound.
Oh well, I'll keep investigating! 2016 SDV8 AB
Post #437666 9th May 2017 1:03pm
Badger
United Kingdom 2018 Range Rover Autobiography 2.0 PHEV Carpathian Grey
See if it does it even if you don't pull away.
I assumed it was the subwoofer powering up
Post #440798 6th Jun 2017 1:53pm
ABAB
Badger - great question.
The noise could well be the subwoofer. From memory it's fitted somewhere in the boot area so would be entirely consistent with where I notice this sound coming from. I have the reference audio, if relevant.
Will try and investigate further. 2016 SDV8 AB
Post #441053 9th Jun 2017 8:55am
First i was reading *Trump when pulling away* Rolling with laughter Rolling with laughter Rolling with laughter All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #441058 9th Jun 2017 11:21am
