Home > Maintenance & Mods (L322) > GOOD RADIATOR BAD RADIATOR?? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hella is OEM, and fitted to the ffrr in the factory... so if you can get one at a reasonable price, you'll be guaranteed a straight swap and easy fit Yesterday I couldn't spell Engineer... Today I are one!
8th May 2017 11:53am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1527 |
And fit a 140kPa reservoir cap, not 200kPa. Ron B. VK2OTC
8th May 2017 12:18pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I fitted a nissen one for my TD6, no problems with it, only issues being it had no drain tap, so gets a bit messy when needing to drain down, and if I remember correctly (although this could have been the condenser replacement) fixings for the fan shroud were a bit different. Fact is, as a radiator, it works. .
8th May 2017 2:57pm |
The Hella rad that I fitted had everything in the right place, except is was missing the Land Rover sticker and the Land Rover price tag!!
8th May 2017 3:28pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3144 |
Go for hella - They are OEM as outlined previously but are known to be better quality. Avoid First Line. |
8th May 2017 3:30pm |
innsanes Member Since: 28 Apr 2017 Location: Socal Posts: 13 |
Thanks a lot guys. I'm new to the forum but everyone is so nice and responds better than rangerover.net forum |
8th May 2017 5:29pm |
^^ Tell me about it!! I've been ostracized to there
8th May 2017 8:45pm |
How long should a radiator last? |
9th May 2017 5:44am |
About 10 - 15 years depending on what type of water and antifreeze has been used... needs to be deionised water, and antifreeze must be ali compatible... get it wrong and they can clog up very quickly Yesterday I couldn't spell Engineer... Today I are one!
9th May 2017 8:20pm |
