Home > Wheels & Tyres > 22" wheels
supershuttle
22" wheels
I have a set of these from Dan they look great but I can't seem to get a very comfortable or quiet ride - they may have to go - I can put the old ones back on. But first I thought I might ask what tyre pressures people run, my car being an L322 doesn't have any recommendations for 22" wheels.
 Geoff
Post #437266 6th May 2017 4:29pm
had the same question re my L405 21''...i ran them at 30/34 but they looked flat so went up to 32/35 and they run well on that..
the L405 manual says 33/36 for both 21 and 22 i believe.. ... - .- -.
Post #437270 6th May 2017 4:52pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
i run 36 front and 38/39 rear on mine.
Smile 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #437280 6th May 2017 5:54pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Not sure you'll find your utopia on 22's. The ride gets progressively worse the bigger you go, I have 21's with summer tyres and 20's for the winter..less bumps in the winter but more road noise due to the tread pattern.
Post #437282 6th May 2017 6:18pm
supershuttle
Thanks guys for the info, I'll try at various pressures to optimise the comfort/noise level. Geoff
Post #437292 6th May 2017 7:37pm
Go back to 20" Geoff..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #437296 6th May 2017 8:25pm
w8pmc
United Kingdom 2016 Range Rover Autobiography TDV6 Carpathian Grey
Does a big difference appear between the 405 & 322 on 22"s, as before buying my L405 AB, the test drives were on 21"s, but i chose 22"s purely for the look & i find them very forgiving & indifferent to the 21"s i test drove with. Paul
MY17 TDV6 Autobiography In Carpathian Grey With Cirrus Interior
Post #437635 9th May 2017 8:59am
Yes it does
The L322 was designed for 18-20's
The L405 was designed for 20-22's
So the suspension on the L405 is tuned to give a decent, albeit firmer ride on 22's - whereas on an L322 the ride is very firm.
I've run an L322 on 20's & 22's as well as an L405 on 20's 21's & 22's
I didn't much like the L322 on 22's and went back to 20's, but am very happy with the L405 on 22's
Post #437637 9th May 2017 9:13am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Mine rides just about the same on 22's as it does stock 18's (shrug)...maybe I'm just used to it but I do swap them out with the change in seasons. I also run 285/40/22....largest sidewall you can run without rubbing 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #437681 9th May 2017 3:32pm
originalracingsnake
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
L405 options down from 22"
Sorry ot drag this thread up from the dead....
My SDV8 2014 ATB has 22's with the Contis fitted. These are not what I'd cal an off road tyre and though the FFRR is equipped with clever electronics they cannot defeat physics... So I want to fit an All Terrain ir Mud Terrain tyre on another set of rims. Question is, "What size rim and tyre combination gives the best choice of AT and MT tyres, AND will fit the L405?". 2014 SDV8 L405 Autobiography. Luxor with ivory. 22's...
Post #450721 12th Sep 2017 5:53pm
n1cktdv8
Mine runs nicer on 21's than it did on 20's and looks so much better. I had a mates when mine was in for service and it had 22's....so hard and rough. Is this where I put the car details and a bit about myself ?........
Post #450728 12th Sep 2017 7:11pm
I found the 21 inch on my former L322 a bit harsh. I think 20 inch is the way to go Thumbs Up All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #450793 13th Sep 2017 9:09am
CS
To originalracingsnake: I'd go for style 502 20" wheels and Goodyear Duratrac 255/55R20 tyres. Only Range Rovers since 1988
Post #450796 13th Sep 2017 10:19am
