Home > In Car Electronics (L322) > Digital speedometer
Skinnyrunt23
Digital speedometer
Does the l322 2012 version have the option of a digital display speedometer through the options ?
Post #437265 6th May 2017 4:17pm
mjdronfield
Not through the options.
Stan and others have done it using the iidtool if I remember right..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #437269 6th May 2017 4:51pm
i've done with the iidtool as said above...i can also keep it on mph when the main dial changes to kph which is handy when abroad so you can compare the kph to the mph speeds you're used to in the UK.. ... - .- -.
Post #437271 6th May 2017 4:55pm
Baltic Blue
Picture from drivers handbook.
Mine both read MPH. Not as clever as Stan ! G reg 2.5VM Vogue Portofino red 1991- 1999
Post #437279 6th May 2017 5:42pm
