![]() | Home > For Sale & Wanted > [For Sale] overfinch tigers 22' |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
There replicas if your not sure. _____________________________________________________
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Really? They have the stamps inside of the wheels? How can you tell..
If it's the centre cap then I couldn't replace the overfinch ones as it's a larger diameter so had to get a Range Rover sticker to hide the beaten up o/f ones |
There should be stamps on outside and the wheel inlays at bottom are different, thats also what i was told
Apparently it's a different run of wheels, I have the first ones. Wonder if Jordan from overfinch is still around? I've had it verified that fakes don't have internal stamps due to copyright issues..I need clarification now lol |
must admit the bigger centres are usually genuine _____________________________________________________
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 ![]() ![]() |
I've been told that they only had over finch on the face if they came as part of a complete body package from OF but you could spec tigers on a new RR from the dealer hence stamp iside. maybe to keep the full of package a bit more special.
I'm intrigued now myself as to why there different. Your explanation sounds reasonable |
recovereruk Member Since: 20 Apr 2015 Location: london Posts: 18 ![]() ![]() ![]() |
Hi there I made enquirys about this to Jordan are overfinch via the showroom in St. John's Wood apparently the early tigers have no outside branding as fitted to my 06 supercharged ff , the later wheels came with the branding on the spoke but all can be verified as original by the gap between centre hole and wheel nut hole i.e. Small ,also the original centres are available from overfinch @ £25 each hope this helps . |
Different class. Thanks for input |
Cheers I need four new centres 👍 _____________________________________________________
No probs I was given the part no for the centre caps as CC01 hope this helps |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Are there any cracks or welds? |
Nothing noticeable.. I'm going to give them a good hosedown and check them properly as there muddy. |
