![]() | Home > In Car Electronics (L322) > 2011 VSE Sub Woofer |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
We have lots of brand new ones in stock sir... Send me a PM so we can get you a price |
jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60 ![]() ![]() ![]() |
PM'ed 2011 4.4 TDv8 Vogue SE
clarencepier Member Since: 21 Nov 2015 Location: England Posts: 4 ![]() ![]() |
I also wonder if my sub_woofer is working. When adjusting the tone controls, adjusting the "sub" control from the extreme minus end to the extreme plus end has no effect on the sound. Would this indicate a non_working sub_woofer? |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
I have been having this dispute with Land Rover for nearly 12 months, mine is a 2012 and the Sub Woofer does not work.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2585 ![]() ![]() ![]() |
I'll check mine for any output tomorrow. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I went through a similar process of thinking my sub-woofer had gone. No change in sound at whatever sub setting.
Hi Muppet
Is it being tried with Logic7 on or off? |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I thought the sub on my 2012 wasn't working properly as it couldn't really be heard unless the volume was high. The solution was to turn the sub up to full and move the front rear/fade towards the rear (about level with the front of the door armrests on the picture) resulted in reduced the front speaker volume and good impact from the sub.
The effect is the same both with logic 7 on and off. I did a bit more investigation using a test CD used for setting up my hi_fi. It has a series of tones at different frequencies. The subwoofer is certainly working down at frequencies around 50Hz but at a fairly low sound level. The conclusion I have come to is that the subwoofer is working but that the effect is quite subtle and is probably only noticeable on music with very low frequencies. In other words, it's not designed to be a boom_boom_boom hear me half way down the street subwoofer but one which just supplements the overall sound if low frequencies are involved. I'm not going to take it any further. |
Thank you so much for the info and tests you performed, and I think I agree with the last statement that it wasn't designed as a " Boom Boom " device...I will try the settings suggested to improve but agree that I don't think it is worth persuing especially after speaking the owner of one that appeared to work, he said that it was only noticable on certain tracks and this was one that I heard..
