![]() | Home > Off Topic > Another computer query |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I've just fitted an additional 1Tb hard drive to my Dell, which is now sitting alongside my existing 160Gb HDD running XP. It's now showing as 'E' drive in My Computer and is sitting there nice and empty! |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Agree with earlier post ^^ ref the size of the system disk. Assuming it's reliable, I'd be inclined to use the 160Gb drive as the system disk and keep the 1Tb for documents, pictures, data.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Nice tool, thanks for that Graham. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Are you running any software that will not work on Windows 7 ? Unlikely, and if not it is time to say goodbye to XP. ( Am assuming you have run the windows 7 compatibility app to check that 7 will run on your PC?)
+1 for backups Joe! |
I think you might be right. Time to get rid of XP. So, I have the windows 7 disc in hand and I'm ready to install over the top of XP. Do I simply drag and drop my files beforehand or will the install disc do all this for me? (Forgive the lack of knowledge on this- its not my day job as you can see!) 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Yes, a drag and drop of the files you want to keep onto the new drive should be fine. You should also do a filesearch on the XP drive for common formats you use like *.jpg, *.doc, *.xls, *.bmp, *.ppt, *.avi, *.flv (not an exhaustive or suggested list), in case stuff ended up somewhere else or buried deep inside My Documents with shortcuts.
All done! |
