Home > Maintenance & Mods (L322) > Bodywork stone chip repair question |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 216 |
I recently bought a LR touch up paint kit for my car as I want to fix some stone chips in the front bumper. The chips have all removed the black paint to reveal the white/grey undercoat below which is very visible against the black paint (the bumpers had been resprayed by the dealer I purchased it from). The kit came with some instructions stating that primer should first be applied to the chipped surface to make the paint stick to it. Is this necessary when applying the paint to plastic, too, or just when applying to metalwork?
4th May 2017 11:45pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Primer on metal, can be used to build up on plastic or as you said many dabs of top coat will build up chips. |
5th May 2017 7:30am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Heres a guide from another forum which you may find helpful. Hope its ok to post it
5th May 2017 8:12am |
Jonrover Member Since: 30 Jan 2017 Location: Shropshire Posts: 14 |
Hi,
5th May 2017 9:05am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
As above, the supplied brushes are useless and too big, I usually use a wooden tooth pick to clean out the hole, they're usually full of polish which makes then appear white, look even worse and won't allow the paint to stick.
5th May 2017 12:18pm |
Thanks for all the replies and the tip about the toothpick. I have dozens of the things to fix so it's going to take a while 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
5th May 2017 6:49pm |
