![]() | Home > Technical (L405) > Technical updates LR access |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35477 ![]() ![]() |
if you subscribe to topix then you can download the bulletin,
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 ![]() ![]() ![]() |
Thank you, just need to work out how to do that now. |
Thanks, I have registered but the bulletin just says
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
Hi Caddyshack,
Thanks Macpaul. I am using Harwoods in Pulborough hut have considered Hunters as 2nd opinion as I wonder if one dealer would be hoping to get you as a service customer ongoing if they look after you. I also wonder if the supplying dealer has more self costed warranty than a fresh dealer who did not supply the car. Thanks for the contact there, will def have a conversation with him.
I have to say that I think no dealer is going to accept a customer's diagnosis, let alone cure!
Sounds very much like the ARC valve block. I had it, went round the houses and the valve block replacement cured it.
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
This was certainly the case when I worked for a truck main dealer. Warranty work was at a rate stipulated by the factory, you want the dealership then you do warranty at XXX amount of £££ an hour at factory set times. Outside work was done at the highest rate you could get away with for however long it took. |
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
Does any one have the part number of the replacement valve block and (ideally) a 'how to' guide to change? Alternatively any idea how much the book labour time is? Many thanks |
