Home > Maintenance & Mods (L322) > Injector coding to ECU???
Muddydisco
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
So mixed messages all around internet land.
DO I or Do I not need new injectors coding / calibrating to ecu on a 2002 TD6 M57????
Wiki post saying nothing about it.
Reason I ask is I have just changed 2 because of leak off. afterwards car was sluggish and not going above 3000rpm.
Now I've found the hidden menu's I have done a reset of fault codes, test 21. and this seems to of improved the problem but is running lumpier.
Now I'm guessing that this reset has cleared the fuel trims and will need running in to reset them????
Anybody tell me. if it does need doing anyone local to Midlands Tamworth that can sort!
Post #436932 3rd May 2017 5:14pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
No coding was necessary when some of mine were replaced. I think there is an ability to forcibly adjust the fuel trims if you have the right gadgetry. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #437045 4th May 2017 11:45am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I use the BMW INPA diagnostic software to keep check on the injectors and running on mine. There is a reset function so I presume that the car is able to adapt parameters over time and this resets back to factory. It is not one injector specific, just does all in one go 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #437218 6th May 2017 2:32am
