Engine Failsafe, Trans Failsafe HDC OFF engine wont start | |
Hello guys I need your help again..
Ive got a RR '04 4.4 V8 Autobiography.
Yesterday my upper water hose blew. I stopped immediately the engine. After half an hour I refilled the coolant system then started the engine and everything was working normally. Until this morning.
This morning I started the engine it was running smooth as usual. Then just before I jumped in to go out of the garage the engine idle suddenly started to be very lumpy so I stopped the engine.
I tried to restart the engine and it does not start again.
Computer says Engine Failsafe, Trans. Failsafe, HDC Off...
I connected my OBD diag to read the fault codes and the diag device can not find the DME.
What happened? Maybe some water causing a short circuit somewhere from the yesterdays problem?
For the full story I had a fault code "Battery Disconnect Unit 1" maybe its related to this fault.
Any advice?
