Home > Technical (L322) > Supercharged reduced performance
Les40
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Hi having a mare.have used the search function but to no avail..have read there is a fuse in the rear fuse box relating to either the fuel pump or super charger. Can any one shed any light on this cheers les
Post #436491 30th Apr 2017 5:10pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Fuse 7 15 amp is the fuse in the rear that looks after the auxiliary coolant pump. Mine keeps blowing and I've been trying to find out what else is on that circuit.
My rear fuse box is completely different to the handbook????? 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #436514 30th Apr 2017 6:44pm
Nine times out of ten the auxiliary coolant pump has gone pop , why are you both looking at the fuse first? 2008 MY Supercharged
Post #436587 1st May 2017 10:19am
pld118
Re: Supercharged reduced performance
Les40 wrote:
Hi having a mare... relating to either the fuel pump or super charger. Can any one shed any light on this cheers les
Our 2007 SC suffered a loss of power on the motorway and the reduced engine performance warning light came on. This was diagnosed as being due to a defective water pump which serves the supercharger. The water pump was replaced an the problem was resolved.
Post #436588 1st May 2017 10:28am
V8Noise
I'm not and the OP was asking about the fuse, so I told him.
My pump was changed last October and, due to the fact I was still getting reduced engine performance, the wiring was looked at again in January. I still got reduced engine performance warning so did some research and found that a fuse, in the rear, can cause problems. A little more research and I found that fuse 7, protects the pump and mine was blowing every time the ignition was turned on. The research is not helped by the fact that the fuse box diagram in the handbook, is different to the actual car; significantly.
That's as far as I've got so far and I'm trying to identify if there's any other electrics being protected by fuse 7. I need to eliminate everything else to identify if the pump is no good. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #436677 2nd May 2017 1:52am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had a pump failure on mine that gave me that warning.
Always easy to check a fuse first just in case... Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #436685 2nd May 2017 7:54am
Skylinejgtc
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Sorry to bump this thread but did you find a resolution to your issue, i am having problems with my Aux coolant pump as it doesnt seem to be getting a 12v with ignition on or when started?
Post #525262 18th Aug 2019 2:17pm
V8Noise
My indy ran a new cable from fuse 7 to the pump and no longer does the fuse blow hence the pump works all the time, as it should so no more reduced engine performance. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #525266 18th Aug 2019 3:05pm
Skylinejgtc
Thanks a lot, thats basically what i needed to know, is that fuse 7 in the boot fuses?
Will do that when i get a chance.
Post #525267 18th Aug 2019 3:10pm
V8Noise
Yes, it is and everytime I started the engine it blew. The new cable was added which sorted the problem. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #525269 18th Aug 2019 3:16pm
