![]() | Home > In Car Electronics (L322) > Audio Connectivity Kit VPLME0004 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
there is no difference between the MOST denso unit in yours and the 2006-2008 units so i would say yes it will fit...
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Yes it works perfectly with the early touch screen and all fits
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
Brilliant guys you have made my day |
The items have no arrived thanks to Dan |
link dont work ????? ... - .- -.
updated |
Anthony9633 Member Since: 09 May 2017 Location: essex Posts: 5 ![]() ![]() |
hi guys im new to the forum and love my l322 was just browsing came across this post whats this Audio Connectivity Kit VPLME0004 give you aux i can see in the pics |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
You don't select the aux button for the ACM, it works using the CD button. CD1 to CD5 buttons are the first 5 folders on your connected USB stick and CD6 plays everything which is quite cool if you select random as it jumps from track to track across the complete library. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Anthony, Slightly late reply to your post. Your screen indicates that you do have the MOST (fibre optic) system and no USB connection.
Hi weegie yes it's a 54 plate and in options it says radio cd tv I'd like USB and DVD to watch movies and digital tv aux and then il have rear screens added at sum point coz I can't change headunit otherwise I'd just do that |
thanks for that Ajay im looking for the RSE to buy on the cheap to convert on an well known site |
Lee Marsh Member Since: 21 Nov 2016 Location: Herts Posts: 44 ![]() ![]() ![]() |
Intrigued by the adding of Aux in. How was this done? Does the Denso support BT to later devices apart from (direct wired) early iPods, iPhones |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
oops |
