![]() | Home > Technical (L322) > Issue when starting car when it's hot ! (FIXED PAGE 2) |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Thanks for your reply |
it may well be the coolant temp but when i checked the Code reader live data it read correctly for mine. but let me know if this fixes yours |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
It amazes me that this seems quite a common problem (even across the BMW forums) and yet no one seems to have a definitive answer.
Jacckk Member Since: 31 Dec 2015 Location: Durham Posts: 18 ![]() ![]() |
I discovered that my warm start issue was actually caused by the LPG system. The diaphragm in the reducer was worn and was allowing gas to fill the manifold after the car was turned off, this would slowly leak away if left for long enough. I replaced the seals in the reducer and it's now perfect. |
I'm not sure about b348xyx, but I'm not lpg - just purely petrol. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
thanks for your update jacckk and glad you got yours sorted |
FIXED !!!! starts perfect every time now !!!!
Sounds good to me |
heat from engine helps push the fuel back down the pipes ?
heres a video after car been left sitting for an hour after 20mins drive to get car to temperature.
Going to get a valve ordered 😀 Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
I have exactly the same "hot start" problem and have fitted one of these valves in an attempt to cure the problem but it hasn't made a difference.
