Home > Maintenance & Mods (L322) > trust me only i could do it
HGv driver
Wales
whist doing an oil/filter air filter swap today I have got a fuel leak from the little plastic top off injector 0ne ive managed to super glue the pipe anybody know what the repair will be?can i just unclip the fuel line a replace the little clip with a new one?and if so anyidea what the part is called and where i might be able to get one on a sunday
Post #435632 22nd Apr 2017 7:25pm
HGv driver
Wales
aftersome reading up on my problem i belive it to be INJECTOR T PIECE LEAK OFF CONNECTOR and the fuel pipe where it joins it ,now is it an easy swap for a new T piece?or has the whole injector need replacing thats the last time i service the car nyself
Post #435638 22nd Apr 2017 8:20pm
These T pieces and leak off pipe lengths are easy enough to find on eBay, and it maybe that Europarts or similar may hold stock of them if urgent. The T pieces get quite brittle after a few years, and the O rings can disintegrate, it may be worth having a few spare, just in case more break during the repair as separating the pipe from the T piece can be a sod too.
For example:
http://www.ebay.co.uk/itm/Bosch-Injector-2...SwpdpVX2LD
http://www.ebay.co.uk/itm/Boltstore-Leak-O...bBiMaiUQvg .
Post #435642 22nd Apr 2017 10:45pm
HGv driver
Wales
Thank you Joe very helpful don't suppose you know what diameter fuel hose pipe she needs?
Post #435647 23rd Apr 2017 6:55am
Not sure, without going out and measuring, but the Bosch common rail injector pipe is the one.
This chap sells complete kits
http://www.ebay.co.uk/itm/BMW-BOSCH-COMMON...1677556956 .
Post #435659 23rd Apr 2017 10:16am
miggit
When I was doing the injectors on my Mercedes I noticed the the plastic 'T's' were looking well past there sell by so I replaced them with a brass set... they are the same as the ffrr returns, so this will work fine with your engine http://www.ebay.co.uk/itm/Leak-Off-Connect...SwBPNXSFmC Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #435750 23rd Apr 2017 10:48pm
HGv driver
Wales
thank you all very helpful just have to change them now
Post #435801 24th Apr 2017 5:05pm
miggit
Easy to do, however I would recommend that you use a set of pin nose pliers to remove the clip as they have a nasty habit of pinging off in to the distance when a screwdriver is used!! Yesterday I couldn't spell Engineer... Today I are one!
Post #435811 24th Apr 2017 6:35pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
That's why they are called Jesus clips
As in - "Jesus, where did that go?"
Post #435859 25th Apr 2017 1:08pm
