Home > Technical (L322) > It limped then it died (many times)
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
So after a day or so of the fuel gauge playing up and reading zilch tonight got more interesting. Went out tonight and noticed a slight hunting and lack of immediate power , after couple of miles engine cut out (man that steering is heavy when you are trying to avoid obstacles without it). Pull over and starts right up with no issues but then repeat within the mile, engine hunting then cuts out, repeat etc... Limped it home, now considering A. Setting fire to it B. Remortgaging and repariring it ? Any ideas ?
Post #435340 18th Apr 2017 11:35pm
GraemeS
Find the reason for the fuel gauge playing up and it may well fix the low on fuel condition that is programmed to allow the engine to restart and run for a short distance before cutting fuel again.
Post #435343 19th Apr 2017 3:00am
cass
Look for the easy (cheap) fix first - put some fuel in as it sounds similar to what would happen if you ran out.
If that doesn't work I'd get the fault codes read to look for a clue
Post #435344 19th Apr 2017 4:53am
Freddie The Fish
The fuel gauge started playing up a couple of days ago, knew I only had around 100 miles left so filled it up yesterday. So could this be a self preservation thing that it thinks it actually has no fuel. Not been any distance since the gauge played up but did a ten mile run yesterday when it started happening.
Post #435345 19th Apr 2017 5:24am
GraemeS
Yes, it's trying to prevent the high pressure pump from running dry because that would destroy it. The same precautions occur with the 3.0 T/SDV6.
Post #435347 19th Apr 2017 6:13am
Freddie The Fish
So lumpy running and cutting out could all be explained by the low fuel warning ? After a search I've noticed that some are ignoring fixing no fuel gauge and running round like that, how ?
Post #435372 19th Apr 2017 11:56am
I know Censored all about it - but in answer to your question it would depend on where the fault lies - if it's a dodgy gauge or cable to the gauge then you could ignore it - if its some sort of sensor that also reports to the fault to an ECU then there may be knock on effects as seems to be the case with yours.
Don't confuse symptoms and root cause.....
Post #435374 19th Apr 2017 12:21pm
from rave.
Low Fuel Strategy
The engine control module (ECM) is programmed with a strategy which shuts the engine off before the fuel tank runs dry. This
is to prevent fuel system damage by air being drawn into the high pressure fuel pump.
For additional information, refer to: Electronic Engine Controls (303-14D Electronic Engine Controls - TDV8 3.6L Diesel,
Description and Operation).
A misfire is induced when the fuel in the tank reaches approximately 0.25 liters (0.06 US Gallons) of useable fuel remaining to
alert the driver to this condition. The engine is shut down when the fuel in the tank reaches 0.00 liters (0.00 US Gallons) of
useable fuel remaining in the tank and 4.0 liters (1.05 US Gallons) of un-useable fuel remaining.
To reset the fuel strategy after engine shutdown, it is required that a minimum of 4 liters (1.05 US Gallons) of fuel is added to
the fuel tank, when the vehicle is on level ground. There is nothing that can't be fixed with a hammer😜😜
Post #435397 19th Apr 2017 4:04pm
Freddie The Fish
I'm guessing that's the same for the 4.4 if so thanks that's helpful information and explains a lot.
Post #435399 19th Apr 2017 4:20pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Symptoms similar to my TD6
Fuel pump starting to fail due to bad fuel.
Filter clogged.
Changed pump and filter and brand new again.
Dont know if petrol same but I am guessing canny be that much different.
Mind you, it is a Range Rover so it could something completely different.
Good luck and keep is informed please
Bill Made in Scotland frae 'Girders'
Post #435435 19th Apr 2017 8:54pm
Freddie The Fish
So for those interested it's repaired, pretty mush as listed in this post http://www.fullfatrr.com/forum/topic41061-15.html
Corroded wiring in the fuel sensor, not too bad to repair for the wallet around £200 at a specialist. And a bonus thrown in,DRLs now activated 👍
FTF
Post #436123 27th Apr 2017 7:26pm
GGDR
Nice one! Glad it wasn't too serious. Who did the repair for you? Cheers, Greg
Post #436125 27th Apr 2017 7:30pm
