Home > Maintenance & Mods (L322) > Westfalia towbar
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
Westfalia towbar
Gents i am in a pickle. I currently have a westfalia towbar on the big girl however when i purchased her there was no tongue or neck for it. Is there a way i can get say a hayman reese one on it or even a different car make ie mazda, vw. I have tried toyota and nissan 50mm but they are a smidge to big any help will be great.
Cheers 02 l322 4.4 HSE
Sitting on 20's
All in Buckingham blue
Post #435276 18th Apr 2017 9:55am
its not a standard sized socket, you need to either order a westfalia detachable one to slot into the receiver or whats called a farmer hitch which is an adjustable type. both available to order or some used ones on eBay.
detachable swan neck bar
flange bar.
you have the hard bit to fit on the car already, you just need the attachment, which fits with 1 bolt/pin. the flange type one can be removed and is a bit more versatile as you can add whatever type of ball or ball/pin to it you like. There is nothing that can't be fixed with a hammer😜😜
Post #435305 18th Apr 2017 4:31pm
Tom Heath
United Kingdom 2005 Range Rover Vogue 4.4 V8 Tonga Green
I've got one for sale at the moment which will fit, assuming it's at Westfalia one which it should be. I'm happy to take photos and text you to make sure it's the same.
I'm happy to split the frame and towbar as you only need the removable bit. Mine is the fully detachable one, which enables you to remove the neck and store in the under boot space.
Pm sent with my number.
Cheers. Tom 2005 L322 Tonga Green 4.4l BMW Engine with Touchscreen
GAP IID BT on order!
1966 Mustang Convertible, 5.8l V8
Post #435480 20th Apr 2017 3:44pm
The detachable swan neck is not legal in Australia we have to use a metric version of the clunky old American a bit like the farmers hitch but flat . 2008 MY Supercharged
Post #435518 21st Apr 2017 1:06am
