![]() | Home > Technical (L322) > 3.6 TDV8 Shift Solenoid Change Out |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
LR changed mine on my 3.6 and I think it was pretty straight forwards, they thought it was leaking from there but it turned out to be from the high low position senor. Check the contacts on that too. There is nothing that can't be fixed with a hammer😜😜
Dantnz Member Since: 28 Dec 2016 Location: Isle of Wight Posts: 10 ![]() ![]() ![]() |
Thanks for the tip, I'll check the contacts on the position sensor too. Pretty sure that's ok as its still allowing me to drive and showing position in 'high' just not allowing changes.
